EOS R7 How to get clean HDMI output, live view, and movie recording simultaneously
simon_1
Hello, since Canon Support has not given me a suitable solution, I'll try it here.
I have owned the eos r7 for a long time for taking photos. Recently also for filming. I have bought an external monitor (Feelworld F5 ProX) which works with HDMI so everything fits with the inputs on the camera.
But now I have the problem that if I want to use both displays (camera screen and external monitor) it doesn't work. It works but the recording cannot be started. So with the EOS r7 there is no way to start a recording with Clean HDMI. It is possible to use only one display, i.e. without camera screen only with external monitor, but then I have all symbols on the external monitor, so no "Clean HDMI" image.
So my question. Does anyone here use the eos r7 Professionel for filming with an external monitor (without recording function) and can tell me how or what he did? I bought the external monitor to have another display without the camera symbols and also Not top have all the symbols on the other monitor.
Maybe there is someone who has/had exactly the same problem and has a suitable or practical solution how to film professionally despite the problem.
Just let me know if you have any questions.
Thanks in advance.
5 REPLIES 5
p4pictures
Unfortunately selecting clean hdmi output means no in-camera recording.
You have a choice of clean hdmi output and no in-camera recording OR symbols on the hdmi output and in-camera recording.
Brian
Okay, yes, I've already found that out. Is there any way that I can get clean HDMI via a gadget or a device that I attach to my camera rig? Similar to when I connect the cam to my PC and put a capture card in between to get Clean HDMI. So my question is if there is anyone here who works with an eos r7 and an external monitor and has somehow managed to get Clean HDMI or an external monitor without the camera icons.
Is there actually a reason why Canon does not offer to record with Clean HDMI? Other camera brands have this too. Or do you think there might be an update in the future to change this?
Most likely the reason is heat generation inside the camera. But I'm not a Canon camera designer.
Brian
stevet1
simon_1,
One option might be to use an HDMI capture card.
Steve Thomas
MaiconMartins
The Canon EOS R7 is an excellent camera that has attracted many content creators, filmmakers, and audiovisual professionals due to its quality, affordability, and versatility. However, the HDMI output limitation—preventing internal recording when an external monitor is connected—is a major downside, especially for those working on structured productions like short films.
In larger productions, having both the external monitor and the camera's built-in screen functioning simultaneously is essential, just like it is on the Canon R5. This allows directors, camera operators, and assistants to monitor the image without sacrificing internal recording. The absence of this feature in the R7 is frustrating and may push professionals to consider other brands that do not impose such limitations.
I understand that this restriction might be related to power consumption and overheating. However, overheating depends on the working environment, and there could be a way to optimize this feature, allowing users to choose the best configuration for their specific situation.
One possible solution would be to provide configurable HDMI output resolutions, such as 480p, 720p, and 1080p. In most cases, external monitoring is just for reference, especially on small screens, where there is no need for 4K output with high bitrates. Offering lower-resolution options could reduce internal processing and minimize overheating while still giving users the flexibility they need.
If this limitation is purely technical, it would be helpful to have an official statement from Canon to better understand the reason behind it. And if it is something that could be adjusted via firmware, this would be a fantastic improvement that could make the R7 even more competitive in the market.
Is there any possibility that Canon will review this issue in future updates?
