07-24-2024
12:08 PM
12:16 PM
I now have a second SD card to use in my EOS R7. Card 1 is in Slot 1. Do I format Card 2 in Slot 2
EOS r7 (using Windows 11 on my pc but I don't think that detail is relevant to my question).
07-24-2024 12:22 PM
You can format a card in either slot, there is nothing special about one slot or the other for formatting a card.
When you select the format menu option you will see a display where you can choose the card you want to format. Either tap on the card2 use the dials or joystick to select the card to format.
07-24-2024 01:06 PM
Just make sure you format the correct card!
I can see the post here in my head: "Help! I formatted the wrong card in the camera! Can I get my pictures back!"
07-24-2024 12:22 PM
07-24-2024 01:06 PM
07-24-2024 02:34 PM
will do
