EOS R7 Auto Exposure Bracketing and High-Speed Continuous Shooting Together
mrhengy
I like to do a lot of wildlife photography, about 2/3rds being birds, and I have settled on my preferred settings for my Canon R7, based on my skills, what feels comfortable, and what I feels gives me the best photos.
Except for one thing: Using AEB and High-speed Continuous Shooting (+ or non+) together. I like to bracket, because I find that with fast moving subjects, I can't react fast enough to change exposure compensation manually. I find that a +/- 1 stop both ways gives me the safety I want. High-speed Continuous Shooting should be obvious.
However, when used together, the camera will only shoot 3 frames, and then I have to release the shutter button, and press it again for another 3 frames. (AEB is set to 3 frames). Now, most of the time this is fine - it gives me time to recompose, track my subject, etc. But every now and again, I'd like to just hold the shutter and roll off more than 3 frames. I have been up and down the camera menu and manual, and I can't find a setting to change this behavior.
Does anyone know of a way to change this?
14 REPLIES 14
Waddizzle
I do not understand what it is you’re trying to achieve.  The two settings are pretty much mutually exclusive.  One is typically used with still subjects using One Shot AF mode and Single Shot Drive shooting mode, while the other is typically used with AI Servo AF mode and Continuous Drive shooting mode.
You cannot really use exposure bracketing during action photography.  The image is constantly changing, so each successive shot will be different from the previous shot.
I do not use AEB to do HDR, and do not do fast action shots. Birds typically stay still for long enough that 3, 6 or even sometimes 9 frames are almost indistinguishable (subject wise). Therefore, I find AEB to be of benefit, so that I may choose the one with the exposure I like.
Maybe do not think of my intended use, only that I want to use High-speed Continuous Shooting and AEB at the same time, and would like the camera to NOT stop after 3 frames. I want to shoot the bracketed sequence for as long as the camera is able, without having to release and press the shutter button after every 3 frames. If there a way?
Thank you.
amfoto1
This is an either or situation.
There is no practical way to set up any camera to shoot bracketed exposures in continuous bursts.
You just need to learn to trust your exposure settings.
Be sure to shoot RAW or CRAW, to have the most latitude to make exposure corrections.
If shooting in variable lighting conditions, use one of the auto exposure modes... AV, TV, M + Auto ISO. Maybe even P (not my personal favorite). With these you might also use ETTR technique.
You also could set Safety Shift, where the camera will override your exposure settings. I don't really trust it or know if it will slow down burst rates or whatever.
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2), EOS M5, some other cameras, various lenses & accessories
FLICKR
That's too bad. Really seems like something Canon just decided for users, but could have easily made an option in order to cater to people's shooting styles.
I do not think you understand what you’re being told.  Your intended use has nothing to do with the two functions being mutually exclusive.
Try using the 2-second shutter delay timer, instead of continuous shooting while you have AEB enabled.  The camera should automatically fire the entire sequence at the highest available frame rate.
mrhengy
I knew this was going to happen. Perfect timing, as DPReview just went down.
I come here with a perfectly valid question, only to get told I'm not using my camera right, no one should ever need to do that, or the two were never intended to be used together and I'm absurd for even trying. If there is no option to do what I want, a simple "no" would have sufficed.
Thanks everyone.
Thank you.
Your goal posts are moving, BTW.
Your focusing on what you think I should be doing given my subjects.
I want to use AEB in HS continuous shooting mode for as many frames as the camera is capable of without having to release and press the shutter ever 3 frames. Simple as that. Forget every other one of my posts.
Is there a way to do that. Yes or no?
No.  No camera made by any manufacturer allows that behavior.  Try using the two second timer like I suggested.
BTW, I am only going by what you write.  You made it clear that you wished to use these features on “fast moving subjects.”  Like is said, your intended use is irrelevant.  The two features and mutually exclusively   You get one or the other.
