10-09-2020 06:51 PM
My Canon EOS R6, sometimes after shooting, the viewfinder and display turn off for a few seconds without responding to any camera function, I need help with this. Please if someone could help me in Spanish. thanks
10-10-2020 01:00 AM
Hi there,
It sounds like the camera may be processing in that time when it is non responsive. This is usually the result of an SD card with a slow write speed, but it can also be made worse when shooting Dual Pixel RAW images, HDR or long exposures and especially if noise reduction is enabled in the camera menu.
10-12-2020 10:59 AM
Thanks for your help. The memories I use are those recommended for the camera, I don't use HDR and neither does Dual pixel RAW, with my files being RAW I don't have noise reduction enabled either, and generally I have to turn off the camera and then turn it on. Excuse my english
10-12-2020 12:11 PM
@GCRobles wrote:Thanks for your help. The memories I use are those recommended for the camera, I don't use HDR and neither does Dual pixel RAW, with my files being RAW I don't have noise reduction enabled either, and generally I have to turn off the camera and then turn it on. Excuse my english
What manufacturer, model, and GB capactiy memory cards are you using?
10-12-2020 12:35 PM
10-12-2020 03:24 PM
@GCRobles wrote:
I use, kingston 32GB 300MB/s
Is that a full size memory card? The only current Kingston 32GB SD products that I can find are all micro-SD cards. I strongly recommend changing your SD card to a different brand, Lexar or Sandisk.
I use these. These are full size cards.
