EOS R6 - live view shows perfect but captured jpg are corrupted and raws are fine
sigma3585
hi
while shooting an event every thing was fine ..then i noticed captured images shows very bad pixel and lines on LCD and viewfinder.
now issue is that camera shoot perfect in daylight and shows captured photo on camera lcd and viewfinder perfect but at low light shots captured jpg are corrupted in colors and raws opened in DPP are perfect
while camera is ON everything from scrolling menu and setting works fine and LCD shows perfect live view
but when i scrool captured images on lcd , screen shows weired pixell and red lines on lcd and VF but same CR3 files opened in DPP looks fine
please help about this issue
thanks
here are images link
https://drive.google.com/drive/u/2/folders/1XafxBZ2tT6toVzYVDbpjISg688B-niNf
7 REPLIES 7
jrhoffman75
Hi. You will need to allow all access to the folder so we can access your images.
stevet1
sigma3585,
Just out of curiosity, what image quality do you have set?
Try changing that and see if it makes a difference.
Also, in DPP, what happens if you take a RAW file and do a File>Convert and Save and save it as a Jpg? Is it still corrupted?
Steve Thomas
jrhoffman75
Are your posted images a screen capture from DPP? It looks like you have the clipping alert enabled and the dark areas in shadows are showing up as blue.
folder is open now for every one
image quality set to RAW+ JPG (L)
in proper daylight most images(raw+jpg) shot are perfect captured and show perfect on camera LCD and VF
but JPG images capture at high ISO at evening are very bad and looks like as shared in shared link
but same at high iso or low light images shot in RAW looks bad on LCD panel but when opened in DPP they are perfect and editable and converted to jpg perfectly
dont know its in camera RAW to JPG conversion hardware or software issue
images shared are original jpg images .....highlights clipping mode is off
"dont know its in camera RAW to JPG conversion hardware or software issue"
which software are you using to view the JPEGs?
Can you post the RAW files to your storage link?
