EOS R6 Shutter problem ?
Dangermoose
I just got my refurbished R6 in the mail yesterday and while taking some test shots of low light settings I noticed a lot of black banding across my photos. These photos were taken with multiple light sources, and NO flash.
The banding is consistent with the camera orientation. So when i hold my camera in landscape the black banding is horizontal, when I turn it to portrait the banding is vertical. Does this look like a shutter issue I should RMA for?
R6 body (canon online store)
Canon EF>RF adapter with control ring
EF 85mm L ii lens
4 REPLIES 4
ebiggs1
"... while taking some test shots of low light settings  ..."
And, while shooting in daylight is it OK?
EOS 1DX and many lenses.
jrhoffman75
What type of lighting? Perhaps it is a flicker issue?
Need to research.  I thought I read something about this somewhere.  Might be mistaken though.
Can happen in video...  still looking for confirmation in stills:
Canon R6 Sensor Banding? - Canon Community
***Ernie's suggestion of a settings reset is where I would start.
Your issue does not look like banding.  Flicker as John mentions seems more likely.  Your issues looks like downright shadows, so I would test in daylight.  If you are using electronic shutter, change to mechanical.
Other test scenarios:
Shoot in RAW,  Daylight.  Set ISO to 100 and test.  Do you see banding or shadows?
Now change ISO to 200 and perform the same test.  Is banding/shadow still present?
Don't worry if there is an issue.  Canon will make it right.  I've bought plenty of refurb gear and all has been well.
Anonymous
Not applicable
Try turning on Anti-Flicker shooting in the menu. It does look like flicker caused by fluorescent or LED lighting. Anti-Flicker setting should help if this is the issue.
