EOS R6 Menu and touch screen locked.
juliadd
I was recently on a photography outing in unsavory weather conditions, rain and wind.  I had my camera as best protected as possible.
After mounting my Canon R6 on tripod I was not able to use the touch screen, menu or review buttons.  The shutter button worked no problem ( I use back button focusing) no issues but when I tried to change focus point on the screen, it would not budge.
I switched camera off, took out battery, card and put back again. all to no avail.  Over night I took off lens, battery, cards etc, still not working.  I have no idea why this has happened, camera is only 2.2 years old with a relatively  low shutter count.
Please help, I would appreciate any advise as to how to fix this problem.
Julia
11 REPLIES 11
Waddizzle
The R6 should have weather sealing.  A few drops should not have damaged it.  Did the camera actually get wet?  If so, how much exposure to water did it experience?
Also, check the position of the [LOCK] switch.  There are camera settings that can disable those touch control and other buttons.
Bkerwin234
Hello Julia, I am having this exact same issue. The camera turns on however when I press the menu button and the playback button are un responsive. when I press them nothing happens. I made sure the lock button was off. Let me know if you find a solution. thank you and good luck
Brian
patentloafers
Anyone d we get a resolution? My R6M2 is now doing this. It’s been babies too. Just out of no where stops working.
Hi patentloafers,
I'm sorry to hear your EOS R6 Mark II is having issues. Cameras can freeze or buttons can become unresponsive for a wide range of reasons, so to assist you with what is happening in your case we would need some more information. Is the issue that the camera is completely freezing and becoming unresponsive, or is the issue that specific buttons are not working? If the issue is with some buttons aren't working which ones aren't responding? Are you seeing any error messages on the camera, and if you are seeing an error message what does it say word for word? What function is the camera using when it is freezing?
It’s any function that it occurs. All buttons don’t work. I can use wheels tho to change aperture and shutter. Other than that it’s a no go! No error messages unfortunately. THANK YOU
Did not get a solution I sent my camera to canon however they said it was “too corroded” even though I never really let it get wet. Had to sell it used for parts because canon would not fix it so it was my only option to get some money out of it. While waiting to sell it I used my other r6 and noticed while holding down the shutter button lightly to focus it does the exact same thing that my broken r6 did. My thoughts are that maybe something in the shutter button either got stuck or broke. Just a theory though not a camera expert. Best of luck with your camera!
-Brian K
Thank you! Honestly what you’re describing seems highly plausible. The autofocus is going CRAZY. It’s like on overdrive.
Have you checked that the Multi Function Lock switch is not enabled?  The lock switch does what it says.  It locks the controls of your camera.  If you are feeling for the shutter or video record buttons, it is quite easy to enable that by mistake.
You can use the menu to configure what that switch will or will not do.
cheers, TREVOR
If your camera had a lot of corrosion, it could be from being in a very humid place without environmental control, or having the camera in an area near the sea - even using it on a beach with an on-shore wind can pose a threat.
A good thing to do is store your camera gear in a drawer or cupboard with crystals for reducing moisture.  Never take your lens off when its wet, or when you are on a windy beach, and always point the body downwards to avoid moisture, dust and debris from getting into the body.  Preferably change lenses inside a building.
cheers, TREVOR
