EOS R6 Mark II dark shadows on all images
Lauramauldin
Hi everyone! I just got a new 6d Mark II body and attached a 50mm lens with an adapter. I am using new SD cards and every time I take a picture there are these dark shadows that show up on the picture. Sometimes I can see the shadows in the viewfinder but not on the screen if I switch to it.
15 REPLIES 15
Are you using the electronic shutter by any chance. That will cause banding under certain lighting conditions especially under LED lighting.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
I did have electronic shutter on. I switched it to mechanical and it’s even darker and bigger shadowing areas now
Were you shooting with electronic front curtain or the fully electronic shutter. Are you using an external flash if so what model. Is it Canon or a 3rd Party flash.
-Demetrius
I reset the camera settings and it auto sets to Electronic first curtain. After resetting camera settings the shadowing has gone away. I do not have a flash attached to the camera.
Peter
The main issue is the light source, flickering light, and the reason you see it is because you used a short shutter speed.
1/50 or 1/60 sec or slower should be safe to use.
ebiggs1
"The main issue is the light source, ..."
I agree just the unusual circumstance of lighting conditions.  But a good confidence measure would be the do a full reset then set it to P mode and on a nice day go outside and take a dozen random shots of stuff. Set ISO to 200 and use One shot if it does well everything is OK with the camera and it truly was just that situation.
EOS 1DX and many lenses.
