12-17-2022
11:01 AM
04:17 PM
I can't get any of the flash function settings to work on this camera
12-30-2022 07:43 PM
Hi kwrichard77,
To assist you with this issue we will need to know what flashes you are trying to use with the camera. The functions available can vary depending on the flash that is being used. We will also need to know which flash functions you are trying to use
If you want to check the manual for information on the flash functions they are on pages 211-231. If you need a copy of the manual it is available HERE.
12-30-2022 08:05 PM
kwrichard77,
Your R6 mkII has a multi-function shoe. The following might be helpful for reference.
Multi-Function Shoe Adapter AD-E1 (canon.com)
3rd party gear may not be compatible. We will await your reply.
12-30-2022 08:11 PM - edited 12-30-2022 08:25 PM
What kind of flash system are you using. Canon's speedlites or a 3rd party flash system. Canon's older speedlites released prior to 2008 (220EX, 380EX, 420EX, 550EX, 430EX and 580EX) CAN NOT be controlled from the camera menu. All settings must be changed on the speedlite unit itself except flash exposure compensation. Speedlites released in 2008 (430EX II, 580EX II) and later can be controlled by the camera menu.
-Demetrius
Happy Holidays
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM (Retired), EF 50 F/1.8 STM, EF 85mm F/1.8 USM & EF 70-200mm F/2.8L IS III USM
EOS 40D (Retired) & 5D Mark IV
430EX III-RT, 470EX-AI & 600EX II-RT
12-31-2022 01:57 PM
Westcott flash system. I'm working with westcott support
12-31-2022 02:01 PM
westcott flash system. FJ400, 200, 80. trying to use HSS. Works on R6 but not R6MKII
12-31-2022 02:20 PM
Your flash unit or system may need a firmware update to work correctly on your new camera.
-Demetrius
Happy New Year
12-31-2022 03:07 PM - edited 12-31-2022 03:08 PM
@kwrichard77 wrote:Westcott flash system. I'm working with westcott support
Good!
This is a question for Westcott, not Canon.
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2), EOS M5, some other cameras, various lenses & accessories
FLICKR
03-05-2023 07:29 PM
Just curious if you ever got your R6II to work with the FJ400?
