09-04-2024
07:57 PM
08:59 PM
Tiffany
Hi guys, how do I get a ethernet cable to work on the R6 ? I can do it wireless ftp. But im wanting to do it by cable.
09-05-2024 12:47 AM - edited 09-05-2024 12:56 AM
Hi Cody and welcome:
The only R-series cameras with ethernet RJ45 ports are the R3 and R1, the R5II can use the BG-EF20 battery grip as that variant of the grip has a ethernet port. The R6 series cameras do not have the protocols for ethernet connectivity and you can't load them, so I doubt the USB work-around you hope for would work.
If you want to download the files fast, take the card out and put it in a SD card slot attached to your computer and copy the files to your hard disc. You can use an USB cable, but it's actually slower.
09-04-2024 09:37 PM
CodyGrubbs,
I don't think the R6 has an ethernet port. If you look at the specs, it mentions a USB port and an HDMI port, but there's nothing about ethernet.
Steve Thomas
09-04-2024 10:21 PM
would it work with a ethernet adapter in the usbc slot /
09-05-2024 12:26 PM
thank you for letting me know, i greatly appreciate it.
09-05-2024 02:15 PM
Always welcome Cody!😊
