EOS R6 F-stop limited to F8 to F11
Mike19
My R6 is only allowing a range of F8-F11 no matter what lense I use. Is it stuck in a mode or does it need repair
p4pictures
I would also check if you have limited the aperture range in the custom functions. It's on page 2 of the custom functions menu unser Set aperture range. If there is an asterisk on the right side then some limitation is set.
Brian
6 REPLIES 6
rs-eos
What lenses have you tried? Have you tried resetting the camera?
Ricky
deebatman316
What lenses are you using please provide the full and complete name. Partial names won't help us. Are these adapted EF lenses. Are these Canon or 3rd Party lenses. Is a Mount adapter being used if so is it Canon or a 3rd Party Mount adapter. Please clarify that you're using the original EOS R6 or the EOS R6 Mark II
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 85mm F/1.8 USM
p4pictures
Brian
I have tried my 70-200 2.8, 50 1.8
have not tried resetting; don’t know how I’m kinda new to this
Omg Brian you got it! Thank you. Not sure how that happened don’t ever remember intentionally doing that. Thanks again
Glad to help, could you please mark my post as a solution so that others will find the help too? Thanks
Brian
Holiday
