07-25-2024
07:38 AM
09:13 AM
Hello Team,
I has Canon EOS R50 (RF-s18-45mm f/4.5-6.3 IS stm & RF-s55-210mm f5-7.1 IS stm) Mirrorless kit.
In both lenses Control Ring not work with custom function setting. Functions available for customization like AF, exposure, ISO, WB, K etc.
Please suggest
07-25-2024 10:58 AM
These two lenses have a combined focus and control ring. Since the lenses don't have a switch to change the operation of the control ring between focus and control ring operation, you need to make the change in the camera menu.
Check the setting on the AF4 menu, you should see the option for Focus / control ring, and it is set to FOCUS by default, change this to control and then the control ring will follow the functions you have assigned.
07-25-2024 10:58 AM
