EOS R50- Control ring doesn't do anything
amir36
Hi
I have the canon r50 camera with as a kit
with two lenses
I tried to use the control ring and it doesn't do anything
even after I set it up in the menu
olease let me know how to use it
6 REPLIES 6
March411
amir36, welcome to the forum!
What lenses came with the kit?
I threw my 15-35mm on the R50 and tested the control ring function and it worked fine. I programed exposure compensation.
What do you have programed on your control ring? Are you half pressing the shutter button when attempting to make adjustments with the control ring?  If you are not half pressing the shutter button when making the adjustment give it a try.
Marc
Windy City
Great minds discuss ideas; average minds discuss events; small minds discuss people. Discussion is an exchange of knowledge; an argument an exchange of ignorance
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
FloridaDrafter
Some of the "kit" lenses have a switch on them that change the function of the focus ring, if I remember correctly. So the focus ring may have a dual purpose of either a focus or control ring depending on what position the switch is in. Check the manual for your lens to verify this. There is also the possibility that you have to press a button on the back of the camera to activate the control ring. The later will be mentioned in the info as you configure the control ring in camera (my R5 II is like that).
Newton
p4pictures
I'm assuming that your kit lens is the RF-S 18-45mm. If so there is no switches on the lens to select AF/MF or the function of the control ring. This means you need to make such selections from the camera menu. AF/MF selection is made at the end of AF1, and the control ring function is made from AF2.
To make the control ring work as a control ring not a manual focus ring you need to go to the purple AF menus, AF2 and there you will find the setting to determine the control ring function, either focus or control. Set it to control and then it will be a control ring. If you don't do this, then the function is focus ring, and if the camera is in AF then it does nothing.
Here's the manual page:-
https://cam.start.canon/en/C011/manual/html/UG-06_AF-Drive_0110.html
Brian
and put the control ring on Tv
but in some modes I dont see a shutter speed change when using the control ring
and in other modes changing the speed changes iso but not the apperture
If you are using P, or Av mode then the control ring cannot change the shutter speed, as the camera is controlling it.
If you use M, Fv  or Tv mode then you can control the shutter speed.
If you are using AUTO ISO then changes in the shutter speed in Tv, M or Fv modes will mean that the camera changes the ISO to compensate for the changes in shutter speed.
Brian
sjskjtn5
Option 1 - If your lens does not have a physical “focus/control ring” switch on the barrel then DO THIS ON YOUR CAMERA:
1. Press <Menu> button
2. Tap on <AF> menu
3. Tap on or swipe to screen 6 in this menu (on my EOS R7)
4. Tap on the <Focus/control ring> option
5. Tap on <Use as control ring> then tap <SET OK>
6. Now go ahead and customize the control ring as described in your camera manual  - search in the manual: “customize buttons and dials”.
END
Option 2 - If your lens has a physical “focus/control ring” switch located somewhere on the lens barrel then simply switch it to “control” and then go ahead and customize as per the camera manual instructions.
