09-18-2023
07:14 PM
04:22 PM
James_C
Our new R5 has had varying success connecting to EOS Utility wirelessly. We are running windows 11 on our Razor Blade 17 RZ09, and Surface Studio 2. Wired it connects right away to both computers, however we have had constant issues with it connecting wirelessly. We have tried using the network that the camera creates as well as using an already established WIFI network. We were able to connect to the Surface only by using an already established network but cannot connect the Razor, and cannot connect to either computer using the network that the camera creates. Everything works perfectly until we open EOS Utility and click "Pairing over WIFI/LAN" and our camera model never appears. I will also note that we are connecting to the 2.4GH network, not the 5GH.
We used to use a Canon 5d M IV and had no issues with it connecting wirelessly to any computer. Since the R5 will connect to our Surface using an established WIFI network, but not the Razor, we are thinking it may be a computer setting issue. Anybody else experiencing this/know what may be going on?
09-19-2023 05:50 PM
You're welcome.
09-19-2023 06:36 PM - edited 09-19-2023 06:39 PM
Bob,
Excellent. Waddizzle and I hit on this last week. Where both of us basically indicated the WebCam Utility might be the source of the wireless connectivity issues.
The utility allows wireless connections if you subscribe, but its services (if running) can interfere with wireless connectivity without a subscription. It appears unfortunately, even if the software is not in use.
In the other user's situation, he disabled the running services in (services.msc) and was able to successfully connect without uninstalling the WebCam software.
09-19-2023 06:59 PM
Thanks Rick. I saw that and thought that it might apply here.
01-20-2024 05:39 PM
I have similar issue with new R5. I had my frist R5 camera couple years ago and it worked with EOS Utility like a charm.
I think it is new firmware somehow affecting wireless features.
For example - I can connect R5 to my home wifi network. While connected R5 will not transfer images to my Mac, nor to my iPhone, nor to Image.Canon
Canon support was unhelpful offering the same steps I have done so many times, at the end they blamed my router, which I used for previous R5 wihout any issues. I love the camera specs for images and video, features wise, specially Wifi connectivity is really buggy.
05-02-2025 08:44 AM - edited 05-02-2025 08:44 AM
I have the same issue however do not have the webcam utility installed on my computer. Camera connects to home wifi no issues but EOS utility does not see the camera. Same thing when I use the camera's wifi node. Any other suggestions???
-- Jeff
05-05-2025 04:59 PM
Hello myersjdo,
I'm sorry to hear that you are having issues getting your wireless setup working. Let's start by resetting the wireless settings on the camera to factory defaults. In the purple antenna menu #2, select [Reset communications settings] and then [OK]. I have attached a copy of the instructions HERE that can walk you through the process of setting up the wireless connection to your computer from scratch for your reference. If you still are having an issue, can you reply with where exactly you are running into the problem and whether there are any messages or errors given.
