03-06-2025
12:46 PM
11:36 AM
James_C
With my Canon R5 Mark II, I got some serious issues with Angelbird CF-Express B cards. Every time I boot-up the R5II in movie mode, the camera freezes instantly after the screen goes on but before the control elements of the screen are shown. It consistently happens with both an AV PRO 256GB and an AV PRO 1TB. It seems as if the camera couldn't access the card or something. Switching off won't work, the battery has to be ejected, the camera has to be put in photo mode before the battery is put back in again. In photo mode though, the camera does boot up and I can switch into movie mode sometimes without freezing. It's a bit annoying since a range of tested SanDisk CF-Ex-B Extreme Pro cards with different capacities all work seemlessly..
The use of the Refresh via SSD Manager and FW update tool of the cards didn't change anything.
Please fix it with the upcoming FW update Canon. ASAP. This is making the camera borderline unusable.
The R5II has FW 1.0.2 installed. I checked disabling all other settings like network and power saver and so on..
03-06-2025 01:27 PM
Spot on Rick.
03-06-2025 01:36 PM
Have you contacted AngelBird about the cards not working correctly in the camera.
03-06-2025 03:39 PM
Please save your current configuration to an SD card. Now reset the cameras, main and custom settings. Retest with the Angel bird cards.
03-06-2025 03:41 PM
Sure, the conversation is ongoing. Taken into consideration though that the cards work as expected in camera, I'd logically rule out corrupted cards. Those Angelbird cards both work in the exact same R5II body in both photo and movie mode. Just when booting up they camera freezes. Also booting up in other Canon cameras like my R5 Mark I and the C300 Mark III (of course after initializing media) is working fine. So my logic dictates an error in the card reading process of the R5 Mark II.
Can you follow my logic?
03-06-2025 04:01 PM
Thanks, this was very helpful. For now indeed the freezing does not occur with the cards anymore. 🙏
06-03-2025 08:25 AM
Hi - can you tell me what the solution was? I also have Angelbird CFExpress cards and am experiencing a different problem with my Canon R5 Mk II - one card has completely corrupted and my computer can’t access it anymore. The second card has some files that I cannot see - but only those taken with the R5 Mk II.
06-03-2025 11:34 AM
I'd never heard of the "Angelbird" brand and maybe I don't get out much or maybe I live under a rock, but what is so special about Angelbird versus "better known" (to me) brands?
06-03-2025 11:40 AM
Anglebird memory cards are geared to videographers. Mainly due to high write speed, build quality and large capacity. Anglebird is also a respected brand for videographers. Their cards are also expensive too.
06-03-2025 12:27 PM
+1 AngelBird cards are top quality. I have 4 now and have been using them since mid 2022. Fast, reliable, with a great warranty.
