11-28-2025
03:39 AM
09:37 AM
Distortion correction is disabled by default on the r5 mark2. In what situations would you want to enable it?
I plan to only use the single lens I have which is the 24-70mm F2.8.
I use Affinity Photo 2 to edit my cr3 images, should I use the "lens correction" (profile for my lens) and the "remove lens vignette" features? They are both enabled by default.
Thank you,
11-29-2025 11:34 AM
You can process the RAW images with the free to download Canon Digital Photo Professional. It can process the images using the Canon lens profiles, but only for Canon lenses, not Sigma, Tamron etc.
11-30-2025 12:28 PM - edited 11-30-2025 12:29 PM
"Lightroom applies Adobe lens corrections as a default, ..."
Lightroom doesn't apply lens correction by default. LR only applies it automatically when it can identify the lens and camera make from the EXIF. if you want to make this automatic for all imports you need to create a preset. If you don't want LR to ever do any lens correction upon import you need to also create a preset for that.
Personally I have a LR preset that applies lens correction and a few other things to every image I u/l to it.
11-30-2025 08:18 PM
I don't understand your response. I feel I was very clear with my questions. I will just contact Canon and not use this forum again. Very disappointing..
12-01-2025 11:27 AM
"I feel I was very clear with my questions. ... (and) not use this forum again. Very disappointing.."
Every so often we get a person that says that and I never understand why. Everyone has given you answers. Sometimes the answer is one you may not like or don't agree with but it is an answer just the same. The amount of experience that lives on this forum has got to be measured in centuries not years or even decades. We are just folks trying to help.
12-01-2025 03:58 PM
I re-read his question. I think he wanted a "yes/no" answer and we might have overcomplicated things. IMO the answer is "Yes" - at least MOST of the time.
12-01-2025 04:08 PM
I would disagree. His question was:
I use Affinity Photo 2 to edit my cr3 images, should I use the "lens correction" (profile for my lens) and the "remove lens vignette" features? They are both enabled by default. "
The response he complained about said:
"The only reason to keep lens correction turned on in the camera is if you want to use the JPEG or the embedded JPEG from the raw file." Since he said he was editing his .CR3 files he could conclude that there was no reason to turn it on.
12-01-2025 05:59 PM
You're right. I was only answering his second question with probably "yes"- mostly. That said, I bugged out on this thread as I have zero experience with Affinity Photo 2 and didn't want to express an uneducated opinion. I had already weighed in on the first with "I would want to enable when saving to JPG on the camera - say if I were shooting casual snapshots that were going straight to a text or email." And that's essentially the same answer- ish, though yours is much more precise (not my strong suit in communications, I'm afraid).
12-01-2025 10:20 PM
I apologize for being impatient. I'm just very frustrated with this and it's been going on for months. I've been back and forth with Affinity so many times it's ridiculous. At first, they told me the lens profile (for my lens) is for the EF version and not the RF version. Therefore, they sent me a xml file that is an updated profile for my lens to use with Affinity Photo. However, this did nothing and have the same results with the lens correction feature in Affinity Photo. After letting them know this, they told me nothing is wrong with the lens profile for my lens! I don't seem to be getting anywhere with Affinity, so I gave up with them for now. I was going to mention this in my first post but I though it's best to keep things simple.
As I mentioned, for my camera (R5 mark2) and lens (RF 24-70mm F2.8 L IS USM) the default Lens Aberration Correction settings are below.
12-01-2025 10:21 PM - edited 12-01-2025 10:35 PM
Without Lens Correction (50mm)
With Lens Correction (50mm)
12-01-2025 10:27 PM - edited 12-01-2025 10:34 PM
Without Lens Correction (35mm)
With Lens Correction (35mm)
