EOS R5 Mark II Hot shoe keeps failing
Trg
My EL-5 flash works consistently on my EOS R8. On my R5 Mark II I get ‘Accessory Status Unavailable.’ Gently blowing out the R5 II multi-function shoe has restored operation several times, but the failure returns fairly quickly. (15+ minutes)  Any suggestions on the best path to take? Thaks for any help.
5 REPLIES 5
deebatman316
Hi @Trg I recommend mounting the flash with both the flash and body off. If it continues to happen you will need contact Canon or the seller if the camera is new.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Thanks very much Demetrius.  I have connected the flash and body with both off, and then turned on the camera and then the flash and get the same result.  Any ideas of what might be causing this or the possible cost of repair?
@Trg only contacting Canon can give prices.
-Demetrius
The problem has been resolved for now.  I bought a wireless transmitter that uses the traditional contacts on the hotshoe. It works great.
Waddizzle
“ Thanks very much Demetrius.  I have connected the flash and body with both off, and then turned on the camera and then the flash and get the same result.  Any ideas of what might be causing this or the possible cost of repair?  “
Try turning the flash before turning on the camera. Wait for the flash to fully initialize before turning on the camera.
s Alison, make certain the flash is securely seated. No wiggle room.
