10-16-2024 01:08 AM - last edited on 10-16-2024 07:56 AM by James_C
One of the reasons I purchased the R5 Mark II was the very short exposure times when using e-shutter. However, I usually use AV and was surprised to find out that when using this mode, I can't use exposure times shorter than 1/8000sec.
Why was this limit set? Can it be removed (without switching to Tv or M)?
10-16-2024 03:03 AM - edited 10-16-2024 03:20 AM
Please see C.Fn Exposure. > Set shutter speed range for an explanation.
https://cam.start.canon/en/C017/manual/html/UG-09_Custom_0030.html
In [P] or [Av] mode, or in [Fv] mode with shutter speed set to [AUTO], the shutter speed is set automatically within your specified range (except for movie recording).
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
10-16-2024 03:32 AM
I'm sorry, but this is not a solution. Set the camera to electronic shutter, Av and very high ISO value, open the aperture and point it at bright source of light. You will see that instead of dropping to shorter exposure than 1/8000, the time display blinks and does not go further down. Only on M and Tv modes you can (manually) set it to anything shorter.
10-16-2024 06:29 AM - edited 10-16-2024 02:45 PM
The camera has complete control over [aperture] in Av mode. That’s the point for selecting it. Similarly, selecting Tv mode allows the user to set shutter speed while the camera has complete control over aperture.
If you want direct control of shutter and aperture, then you should use M mode. Using Fv mode is another option, but it is merely a hybrid of the other modes. I don’t use it because I don’t change my mode often enough to need it.
When things blink in the display, that’s usually a sign that something you’re doing is wrong and the camera is asking for help.
10-16-2024 07:32 AM
Let's assume that I know what AV mode means. Let's also assume that I own those f/1.2 prime lenses and I live in a very sunny place. Let's think of a hypothetical situation in which I want to ise the camera in full daylight, with open aperture. In this situation, even lowering the ISO to 50 won't be enough and I will still get the blinking exposure value, which means that the picture is over exposed. In this situation, I would expect the camera to lower the exposure time to shorter than 1/8000sec, but it won't. The cameta is capable, so... Why not?
FYI: My old Fuji X-T3 did it. There was even a special mode which automatically switched from mechanical to electronic shutter when it found that it needed shorter exposure times.
10-16-2024 02:50 PM
“ I would expect the camera to lower the exposure time to shorter than 1/8000sec, “
I had typo in my reply and just now corrected it. I suggest checking the range settings on your shutter speed for automatic modes. I’m
10-16-2024 08:50 AM
You need to use Tv (Note note 1):
10-16-2024 10:31 AM
Okay, it's an answer, not a solution. Why was this limitation set? Honestly it makes no sense.
10-16-2024 12:40 PM
We are not Canon, we cannot speculate.
