EOS R5 MARK II Best way to learn how to use it
JavierGautier
Looking for the best way to learn how to fully use EOS R5 MARK II in a quick manner, without reading long books. Something like an app. My interest is landscape, birds and macros, my lens canon 500mm, canon 15-35 and canon 100 mm
7 REPLIES 7
Waddizzle
If you are new to photography, there are two learning curves to climb.  One is learning how to use a digital camera.  The second is learning the basics of photography.  There are no shortcuts.
I like to compare it to learning how to play a musical instrument.  You need to learn how to play the instrument.  And you need to learn about music theory and how to read sheet music.
jrhoffman75
Assuming you have a knowledge of photography and general camera use this video is specific to your camera.
https://www.youtube.com/watch?v=0_YOHDcNIsI
If you are looking for general camera use see Waddizzle's post.
R6 Mark II, M200, Many lenses, Pixma PRO-100, Pixma TR8620a, Lr Classic
This video is brought to you by Squarespace. I've been using Squarespace for over 10 years now and I think you should give it a try as well. Get your 14 day trial at HTTP://squarespace.com/froknowsphoto If you decide it's for you, use the code FroKnowsPhoto at checkout to get 10% off your first ...
TomRamsey
Rising Star
Rising Star
Assuming that it is not your first camera check the youtube videos as John pointed out, and go out and take pictures.
Thanks, I am into photography since 2011, the thing is that this camera is complicated for me, I need a friendly and sharp learning tool
Waddizzle
“ Thanks, I am into photography since 2011, the thing is that this camera is complicated for me, I need a friendly and sharp learning tool. “
There is and there isn’t much to learn about to use this digital camera model effectively.  I lean heavily in the direction that there isn’t much to learn for an experienced photographer.
I compare learning to use a new digital camera to learning how to drive a new car.  All cars work pretty much the same way because they must all follow the same rules of the road, as well as conform to the same laws of physics. No magic hover conversion button.
A new digital camera is no different.  It must function in a manner that adheres to the basics of photography.  Except for the simplest point and shoot models, they all allow you or the camera to directly control any one, two, or all three legs of the exposure triangle.
The biggest difference from one car to the next is what the dashboard looks like.  Same with cameras. The biggest difference is what the rear panel looks like.
While the R5ii has a highly advanced AF system, if you disable features like subject recognition and eye tracking, then the camera will behave just like an advanced Canon DSLR.  The main difference will be significantly more AF points. Instead of a few dozen points clustered around the center of the display, there are hundreds of points that go from one edge of the screen to the next.
If you are coming from a DSLR, then that mode of operation is a good starting point.  First select a single AF point in 1-pt AF mode.  This selected AF point is also used as the “Initial AF Tracking Point” in other AF modess.
Next, with subject recognition and eye tracking disabled, enable Whole Area AF Tracking, and enable all AF points by selecting an AF Zone mode.  Use AF Servo mode.  Half press the shutter and hold it.
The camera should light up clusters of SAF points on moving subjects. If your subject is not moving, then the cluster of AF points should “stick” to your subject as you slowly recompose the shot.
I think that it’s crucial to experience shooting this way when you’re first starting out.  You are seeing how the basics of the AF system works. The more advanced Canon DSLRs can also behave this way, but just with fewer AF points.
Observing and getting acclimated to how the basic AF trading works helps you to understand how the subject and eye tracking features work.  The AF point display is entirely different.
Instead of a cluster of AF points on the subject, it changes to a much larger, dynamically resizing, bounding rectangle.  Inside the larger bounding rectangle is a smaller bounding rectangle on the subject’s face or eye.
It’s important to note the size and shape of the inner rectangle.  Because it will never get smaller than the AF squares that you observed in the basic AF mode.  In other words, subjects can be too far away for the AF system to recognize faces and eyes, so that it can lock focus on them.
That’s just a small opening crack of the door.  The rest of the learning curve is going to be simply gaining experience.  The camera may seem to misbehave at times.  More times than not, the cause is usually user error.  Not understanding the limits of what the camera can and cannot do.  This will also be true for your lenses, especially if you are using adapted EF glass.
Tintype_18
I started into photography in 2018 to accompany writing. I have a Canon T7. Downloaded the manual of over 300 pages but narrowed the search to specific things as camera nomenclature, settings, etc. Second was a book written especially for me- Digital Photography for Dummies. Book covered a lot of basics that got me started. Then I discovered the community. One can take lots of photos, note settings for each one for future reference.
John
pcs1
Enthusiast
Enthusiast
Struggling to get the best out of your Canon R5 Mark II? Here're the settings you should change! R5 II Set Up Guide & Cam Settings https://www.janwegener.com/products BRAND NEW Lightroom & Next Generation Photoshop Masterclasses! https://www.janwegener.com/next-gen-masterclass ...
In this video I go through the Canon R5 Mk. II menus including explanations of a majority of the settings. I cover my settings choices for my bird and birds in flight photography for the Canon R5II. 00:00:00 - Introduction 00:01:06 - Shoot Menu 00:27:34 - Auto Focus Menu 00:41:59 - Playback Menu ...
Holiday
