EOS R5 How to know if custom settings are engaged
Florentine
I made a custom setting for my entire set up. How do I know it's engaged when I turn the camera on? Or how do I go to it to engage it? It's not in the Q menu.
Thanks
Anonymous
Not applicable
You chose it the same way that you select P M Av Tv C1 C2 C3 etc. mode selection.
4 REPLIES 4
jrhoffman75
If you created and saved (registered)a custom setting then it should show as a specific mode C1. If you didn't register it when you made all the settings verify that they are still as you want and register the custom setting now. Your camera manual will tell you how to do that.
Florentine
I did save/register. C3. Where does it show up. It's not on my screen. And I can't find it among the 39 times it's mentioned. Looked a number of times.
Thanks
Anonymous
Not applicable
Thank you. There it is and it now shows up on the record screen.
