EOS R5 - Focus Jumping
spvsandy
Conon focus jumping around 10% of time  Setting while doing dance with students doing alot of leaps therefore the settings.  Any help with this
Canon R5 Firmare 2.1.0
Dual pixel = disable, Touch control = disable, Shutter mechanical, Focus bracketing Disable
Camera Focus settings
Servo Af
Method=Face
Subject = people
Eye detect = enable
Continuous = disable
Touch =- disable
Af assist beam = off
Servo 3 = 3 instant on subjects
Switch tracking subject initial = 1
Af pt. set = box dot in middle
Auto = Auto
Sensitivity Af point = 0
af 1 setting at face + tracking
initial point set to #2# AF pt set for Various zones
Going to reset to Auto and test tomorrow
Thanks
8 REPLIES 8
March411
You don't mention the Lens(s). Is it and RF and are you having issues with more than one lens?
Marc
Windy City
Great minds discuss ideas; average minds discuss events; small minds discuss people. Discussion is an exchange of knowledge; an argument an exchange of ignorance
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
Lens is rf 24-105
That’s only rf I have
Thanks
March411
Settings at first glance appear OK but I'll have to look at how I set mine up tomorrow. I use dual back button focus and I want to give you the exact settings. And sorry but I have to ask, that lens has a on/off switch for AF....on?
Marc
Windy City
Personal Gallery
p4pictures
Can you confirm two settings on your camera?
  • AF method from the AF1 menu
  • Initial Servo AF pt for "face + tracking" from AF5
The EOS R5 (original version) can only do face tracking when the AF method is set to Face + tracking, or one of the three Zone AF methods. In the case of the Zone AF methods, it only tracks inside the Zone and will not follow a subject outside the zone boundary.
The setting for Initial AF pt set for "face + tracking" is by default set to AUTO, and with this setup there is no AF point seen on the screen until the camera focuses, at which point it will look for a face in the frame. Your scene with a single person is exactly when I would use AUTO for this setting. If you choose one of the other two options then you get an AF frame that can be moved, it's helpful to "select" a specific subject in a group while using the Face + tracking AF method.
Brian
Thanks
spvsandy
Thanks for fix  Now a heat problem while doing stills
