03-25-2023
05:44 PM
05:53 PM
Tiffany
I have a Canon r5 body; trying to use focus bracketing, but no matter the settings, my camera will only shoot 7 images. My firmware is not up to date, but that is a separate issue.
03-25-2023 09:33 PM - edited 03-25-2023 09:35 PM
Hello, BobArcand!
This is just a guess, but "7" is the max number of shots for exposure bracketing. Double check and make sure you don't have AEB enabled. I've done this myself when in a hurry... I just saw "bracketing" and enabled the wrong one.
Newton
03-26-2023 09:50 AM
@BobArcand wrote:I have a Canon r5 body; trying to use focus bracketing, but no matter the settings, my camera will only shoot 7 images. My firmware is not up to date, but that is a separate issue.
It is a best practice to keep your camera firmware up-to-date. Initial releases did contain a few bugs, but I do not think any of them were related to focus bracketing.
The number of shots can be adjusted from 2 - 999.
03-26-2023 06:16 PM
No, I have AEB turned off. Thanks for trying to help.
03-26-2023 06:20 PM
Agreed, but having issues. I realize that the camera will only take the number of shots required to focus, no matter how many you have selected. Would only shoot 7 on the city hall building across the street, so I moved to a gnarly tree with a lot of branches and detail - still only 7 shots. Also, no matter what shutter I have selected, the camera indicates that it is on electronic, and that electronic does not work with this mode. Have a session with my technical guy on Wednesday, so hopefully I can at least update my firmware. Thanks for the help.
10-31-2023 08:31 PM
Hey I just started having this issue today.... Do you have an update on the issue? Because I too am running into the same exact problem... only 7 photos and changing settings and nothing...
10-31-2023 10:04 PM
Never mind. The issue was either the balance was off or I was to far away from my object.
I do macro shots and using the RF 100 mm lens...
