EOS R5 Electronic Shutter Mode Continuous Shooting Speed Adjustment?
Kilimanjaro05
When I set the R5 into electronic shutter mode and use continuous shooting it appears that the images are taken at 20 frames per second when I would only like a few frames to be taken. Will tapping lightly on the shutter button reduce the number of continuous frames? Any other suggestions?
2 REPLIES 2
FloridaDrafter
For me, when in Electronic and have Drive Mode set to H+, a tap usually results in 1 to 3 frames, so with a little practice it can be done. Fortunately, I don't have to be silent for most of my work, so Electronic 1st-curtains 12fps is plenty enough for me to get the sequences I like and I can get singles in that mode If I want. It does take some practice no matter which shutter and drive mode you use. You can slow them all down by selecting a different drive speed, but you know that I'm sure.
I haven't explored this option, but you can bind "Drive Mode" to a button. I'm not sure how this works, if it toggles or not, but I see it as an option. When you just want to pop off a shot or two in electronic shutter, change drive modes with the assigned button.
Newton
Kilimanjaro05
Thanks for your tips. I wish there were a firmware update that would have a slower speed in electronic shutter mode.
Friends and Family
