02-08-2024
09:55 PM
09:07 AM
I previously used the 5D4 to film nature and wildlife. I usually use a tripod, and under windy conditions, I've always had the IS activated to counteract the wind shaking the lens. Never had any issues and it always worked. However, when I upgraded to the R3, I've noticed that I can no longer leave the IS on while mounted on a tripod. If I do, the footage 'stutters' or 'wobbles' or 'shakes.' It's only really noticeable when viewing on a computer but it's an issue. The R3 had the same results when paired with my older EF 500/4 v1 but it also does the same with my new RF 600/4.
Is this an issue of the lens/camera not recognizing that it's mounted on a tripod? Maybe this could be fixed in a firmware update?
Has anyone else experienced these issues?
02-10-2024 05:22 PM
Hi natureinmotion,
We do not recommend having Image Stabilization turned on while the camera is on a stable platform like a tripod. The image stabilization system is designed to counter shake from hand holding the camera. If the image stabilization system is still on while the camera is on a stable platform like a tripod the stabilizing elements will still be moving around expecting shake from hand holding. When that happens it can cause things like the wobble you are seeing.
That is the case for the EOS R3 and the EOS 5D Mark IV. I understand you said you didn't see it with the EOS 5D Mark IV, but the same issue can happen with that camera. Our cameras do not detect if they are being hand held or if they are on a tripod. Due to that we recommend turning off the stabilization when the camera is on a tripod.
02-12-2024 12:42 PM
Greatly appreciate the response. Not completely sure why I never experienced this before swapping to the R3 but I'm assuming it has to do with the IBIS in the mirrorless cameras. I have spoken to several other professional bird photographers/videographers and they've experienced the same (no issues with IS on tripods before migrating to mirrorless). Again, thank you for the clarification. Will just have to adjust and shoot-on!
09-25-2025 07:14 PM
Hello Hazel_T, I know this thread is from a while ago but had a similar question. I did my first tripod video shoot recently to test everything out, etc. It was by the shore. The videos are unusable due to the bouncing up and down, when the wind blows harder it is quite apparent. I assumed it was due to my old/weak tripod and that I either have to purchase an expensive pod now, or find a way to reinforce it to shoot in windy conditions. Of course, I would have to turn IS off and try the shoot again, but, in the event this doesn't solve the problem, is there something I can do to reinforce the pod that I have for wind, or is there a tripod you can recommend with my EOS 70D? Thank you so very much!
09-25-2025 10:22 PM - edited 09-25-2025 10:29 PM
Please start a new thread for your issue,
While everything Haz l wrote about is true, I am certain that the issue is related to the far more advanced AF tracking than Image Stabilization. This is the most most significant difference between DSLT and MILC bodies.
There have numerous other posts reporting similar issues, but with different MILC bodies. They all seem to have one thing in common. AF tracking is enabled, but the user is not trying to track any specific subject. For example, the user is panning a landscape.
if you wish to continue discussing your issue, then please start a new thread. Thanks.
