06-08-2025
05:55 AM
08:46 AM
James_C
I recently purchased an EF 24-105mm f/4L IS II USM lens from a second hand camera store, after taking my kit lens off (for the first time since I received the camera two years ago) my zone auto focus no longer moves. It is stuck in the bottom right corner and I am wondering what is causing this? The salesman assured me upon sale that nothing was wrong with the lens. The zone auto focus does not move for either lens.
I have an EOS R100
06-08-2025 08:02 AM
I have an EOS R100
To clarify:
1. Everything worked OK with original RF lens.
2. You installed EF-RF adapter and an EF lens and focus frame got “stuck”.
3. You reinstalled RF lens and you have the same problem.
Was in a Canon or third party EF-RF adapter?
What did you try? Remove battery. Reset camera?
06-08-2025 08:18 AM
I have removed the battery, purchased a new battery, taken the lens off and tried my original kit RF 18-45mm lens.
I purchased the EF-RF adapter brand new at an official canon store. The EF lens was purchased at a second-hand camera store
06-08-2025 08:44 AM
The location of AF Zones should not depend on the lens you are using. This is a bigger and heavier lens than the kit lens, especially with a mount adapter.
Try to always be cognizant of the rear display, if you have Touch AF enabled. Your nose or a finger can brush against it and move AF points around. If you primarily use the EVF, then I recommend that you disable Touch AF. I disable all touchscreen functionality, including navigating the menus. Buttons and dials are faster, for me anyway.
What shooting mode are you using? Does the issue arise in Intelligent Auto, Green [A+]?
06-08-2025 08:50 AM
I would expect that powering down and restarting would eliminate the inadvertent touch issue.
A long shot, but try removing battery, lens and SD card. Turn camera on and press shutter button a few times to drain any stored charge.
06-08-2025 08:53 AM
Aside from the stuck focus area does the camera function properly otherwise?
Do you have access to someone with an EF body so you could test lens?
06-08-2025 09:48 AM
This camera doesn’t have a touch screen or a flip display.
06-08-2025 01:51 PM
“ This camera doesn’t have a touch screen or a flip display. “
I was aware that it doesn’t have a flip screen. I assumed that it had Touch AF because the body is basically the M6 Mark II, but with the RF mount.
06-08-2025 03:22 PM
I was surprised by this too. I thought this camera was closer to the EOS Rebel T7 than the EOS M6 Mark II. But I guess I was wrong about that.
06-08-2025 04:08 PM
Hello, Quimo04!
Give this a try: According to the manual, page 151, you should be able to center your focus point/focus area by pressing and holding the "AF point selection" button.
This button, in conjunction with the big dial (arrow keys), allows you to move your focus point/area. If you do not center it when done, it stays there, at least that is the way it works on my R cameras.
I hope I am understanding your issue correctly.
Newton
