EOS R10 M-Fn button only has 1 custom function instead of 5
cranfordrd
I tried customizing the MF N button so I could use it quickly set up pre-shooting. Now the button has only the one function. Can I customise the button to have 5 (customized) functions like it did out of the box? If not, is there a way to get back to the original 5 functions for this button (undo the customization for this button only).
p4pictures
Go to the custom controls, select the M-Fn button, and then choose the Dial function settings from the list of possible options. Dial function settings is the default assignment for the M-Fn button.
Brian
2 REPLIES 2
stevet1
cranfordrd,
There should be a Reset to factory setting in your Custom Function Menu. What does your manual say?
Steve Thomas
p4pictures
Brian
