EOS R Areas of Image Flash Black
ViperEye
re: EOS R mirrorless
Some white areas of pictures flash black, on and off. Kinda looks like a film negative. Is that something that can be controlled in the Menu or is it an in-need-of-repair problem?
Thanks, Jake
Waddizzle
That sounds like an option.  It could be that the saturated highlight alert has been enabled.  You will most commonly see it in the bright sky of a backlit scene.  The setting is in the blue playback menu screens.
2 REPLIES 2
Waddizzle
The "saturated highlight alert" was the key clue. In Menu:  Play icon; option 3; Disable Highlight Alert.
Friends and Family
