04-09-2025
06:30 AM
01:46 PM
My m6 kit lens has error problem that said “lens error, automatically restart” when turned on. Anyone know how to fix this? Or is this a hardware problem?
04-09-2025 08:26 AM
Yes. If it is locked like that and you still get the error message I would say the lens has failed since a different lens works OK on camera.
04-09-2025 07:20 AM
Do you have a second lens to try? Is it a retractable lens? Maybe not extending fully and locking?
04-09-2025 07:27 AM
It’s the 15-45mm kit lense for my eos m6, i have one other lense that’s fine
04-09-2025 07:34 AM
I have that lens for my M200. Sometimes the slide lock that needs to be operated to extend the lens doesn’t snap into position to lock lens open.
04-09-2025 07:40 AM
Oh i just realized what retractable means! But it looks like it extends in and out normally
04-09-2025 07:57 AM
Check that the switch is locked when it extends. Shouldn't be able to retract it if it is locked.
04-09-2025 08:00 AM
U mean like this?
04-09-2025 08:26 AM
