EOS M50 Mark II won't connect to iMac
PhilipBrouard
Unable to connect EOS M50 Mark11 via canon cable to Imac with Ventura 13-5-2.
I've tried everything including rebooting, changing usb port etc
jrhoffman75
Known issue with EOSU 3.17 and Ventura. Try installing EOSU 3.16.1. That solved my connection problem with my 1D X Mark III.
7 REPLIES 7
Anonymous
Not applicable
Do you have Wi-Fi enabled in the camera? It must be disabled to use the USB cable. Also, don't use a USB hub, connect the USB cable directly to the computer.
kvbarkley
and try a new cable.
run image capture manually with the camera plugged in.
I tried disabling wifi and blue T on camera and still Utility 3 is grey.
Thanks
Ill get a new cable.
However Image Capture - sometimes ok sometimes not ok
but EOS Utility 3 never functioning
Many thanks
PhilipBrouard
Could it be a security setting ?
jrhoffman75
PhilipBrouard
Great - that sorted it out - it was the software many thanks indeed
