EOS M200 not turning on
EvangelionAdams
Are there any secret button combinations to try to get it to turn on? Tried several batteries, but not getting anything from the camera led, screen, no sounds, etc.
2 REPLIES 2
Waddizzle
There’s a micro switch on the battery compartment door.  The camera will not turn on if the door is not closed securely.
tried making sure the door is secure, no luck. It isn't damaged or worn, it was mostly used with a dummy battery adapter so the door didn't get a lot of use.
