08-09-2026
01:05 PM
08:48 AM
Hi everyone,
I'm hoping to get some advice from anyone who has dealt with this hardware issue before. I have a Canon EOS M10 that I bought back in 2018, and it recently started acting up.
Suddenly started displaying a "Memory card error" on the screen.
When it didn't throw the error, the camera would occasionally shoot, but the files would end up completely corrupted (half-gray boxes, unopenable, etc.).
At first, I thought my SD card had just died of old age. However, after troubleshooting, I took a flashlight and looked closely inside the camera's SD card slot. Unfortunately, the problem is physical: one of the gold pins inside the card reader is bent completely flat.
I've attached a macro photo I took of the slot so you can see the damage. 50c6d2af-1198-4349-8575-d520eea5f300 (1).jpg
Because the pin is bent, it's obviously not making a stable electrical connection with the SD card, which explains both the errors and the corrupted image files. I know better than to stick tweezers in there and try to bend it back myself, as I've read those pins are incredibly brittle and will just snap off.
08-09-2026 01:54 PM
Hi there!
08-09-2026 01:54 PM - edited 08-09-2026 01:56 PM
According to Internet search, Canon ended repair support for that camera in September 2024. You could always contact Canon support for most current answer - 1-800-OK-CANON. You could also ask Canon about Loyalty Program upgrade.
You might be able to find an independent repair shop to fix it. MPB has three available for ~$350 or less, as a comparison to repair cost.
Depending on how many lenses you have you may want to consider this as the opportunity to switch to the R-series. EOS R50 would be a good transition body.
08-10-2026 12:40 PM
" I know better than to stick tweezers in there and try to bend it back myself, as I've read those pins are incredibly brittle and will just snap off."
This a I agree with that and is likely to happen but at this point what have you got to lose? Right now you are looking at a repair and if you snap it off you are looking at a repair. if you get lucky put the SD in and leave it in. Don't remove it again.
