01-23-2023
04:10 PM
09:00 AM
I just got an used Canon digital Rebel
I am looking to find an Instruction manual or more info on setting it up
01-23-2023 05:15 PM
You can Click Here for the camera manual. Since this camera is new to you. I would reset the camera to factory along with all of the custom functions. Also note this is an older camera. This camera DOES NOT use regular SD cards. This camera uses CF cards (Compact Flash). Most high-end and professional grade cameras use this type of memory card. I would buy 2 of them to use with your camera. Since this is an older camera I suggest you get 8GB cards. Larger CF cards may not be compatible with your camera.
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 430EX III-RT, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D, Sigma 17-50mm F/2.8 EX DC OS HSM & EF 28-135mm F/3.5-5.6 IS USM
01-23-2023 04:19 PM
Hi Rkvideo!
Please let everyone know the model number of your Canon EOS Rebel so that we can further research. Any other details you'd like to give will only help the Community better understand your issue.
If this is a time-sensitive matter, please check out your other support options here: https://canon.us/MyCanonAccount
Thanks!
01-23-2023 04:27 PM
On the bottom it says Canon DS6041 On the front it says Digital Rebel
01-23-2023 04:31 PM
Is it this one?
https://www.usa.canon.com/support/p/eos-digital-rebel
01-23-2023 04:47 PM
On the Front of the camera on the right hand corner. It should say Canon EOS Rebel T8i for example or Canon EOS Rebel T5 as another example. I have a sample picture below to help you find what model camera you have.
-Demetrius
01-23-2023 04:53 PM
On mine, I the bottom on the side that the one in the picture shows is Digital Rebel
01-23-2023 04:55 PM
Yes, but the manuals listed are not what I am looking for. I am looking for one to understand all of the functions of the camera
01-23-2023 04:58 PM
Then you have the original APS-C Canon Rebel Digital SLR. So is this your camera pictured below.
-Demetrius
01-23-2023 04:58 PM
https://gdlp01.c-wss.com/gds/4/0900000274/01/EOSDR300DIM-EN.PDF
01-23-2023 05:01 PM
yes
