10-06-2024 04:00 AM - last edited on 10-08-2024 09:01 AM by Danny
Hi
I'm planning on shooting a slow moving train going over a 19th century viaduct at night. I want to capture the profile of the viaduct and the train carriage lights. The train will be going slow having just left the station. I've an eos90d and efs 18-135 lens - still haven't got a bigger lens - waiting for Black Friday! Please advise on camera settings.
Thanks
Twiddler64
10-07-2024 05:58 PM
Pick up a copy of "Understanding Exposure" by Bryan Peterson. Read, study, practice and learn. Good luck.
10-06-2024 07:09 AM
@Twiddler wrote:
Hi
Thanks
Twiddler64
Are you trying to freeze train motion or do you want to have light streaks?
10-06-2024 07:32 AM
Hi John
I was thinking of freezing the train because the old viaduct has a great profile at night
Twiddler64
10-06-2024 07:44 AM
Hi again John
I should have said that this is great viaduct in the North of England spanning a valley - so the arches are quite atmospheric at night
10-06-2024 09:06 AM
Twiddler64,
Do you want the whole valley to be visible, or do you want it shrouded in darkness and only the train to be visible?
Does the viaduct itself have lights, or will it be in silhouette?
What Shooting Mode will you be using; Av, Tv, M, P?
One thing I was thinking of, is that you could spot meter off the lights of the train and just have the viaduct and valley remain black in silhouette.
If the train is going slow, a shutter speed between 1/250 - 1/500 should probably do the trick. If the train is going really, really slow, you might be able to get by with a shutter speed of 1/125.
Steve Thomas
10-06-2024 12:50 PM
Hi Steve
I really like the idea of spot metering the carriage lights. It's just a relatively small four carriage local train. Plus the back ground around is wooded and only a few lights in the surrounding area.
I'll give this a go on Tuesday night.
Thanks
Twiddler
10-06-2024 01:01 PM
Hi again...
I'm trying to use M as much as possible. I seem to have a problem getting the light settings correct for night photography - still learning- hence my post. The viaduct is only 10 miles from home so I can keep trying different settings - this time of year I can only get one train in the dark after 9:30.
Where I set my camera there are no street lights, but it's on a road with a few cars coming past, which I can't control.
All good fun!!
Thanks
10-06-2024 01:38 PM
Twiddler,
"'m trying to use M as much as possible."
How far away from the train will you be?
If you use a wide aperture like f/2.8 or f/3.5, that 's going to let a lot of light in, and your valley may be brighter than you want. I think I'd aim for a smaller aperture like f/8 or so.. As you narrow your aperture, keep an eye on your shutter speed. Narrowing the aperture might cause your shutter speed to drop loer than you want. In that case, you have the option of raising your ISO a touch.
One approach would be to use Auto ISO, but the camera might pick an ISO higher than what you want and make your picture too bright. You could experiment and see what you think.
Your photography session sounds a lot like shooting the moon. You're exposing for the bright light of the moon and letting the rest fade to darkness. You might read up on that and see how other people approach moon shots.
Steve Thomas
10-06-2024 02:42 PM
Hi Steve
I'll be 150 - 200 meters away at the nearest point. The viaduct sweeps round and the furthest point is probably 400.
10-06-2024 03:03 PM
Can you post an Internet image that portrays the general scene you eill be shooting. I Googled Great Viaduct but didn’t get a hit by that name.
