EOS 80D won't save photos, corrupts memory card
Grim216618
I have a 80D and it won’t save photos. When I take a photo the spinning loading symbol comes up and then corrupts the memory card. I have tried multiple different cards in different sizes.
7 REPLIES 7
kvbarkley
Where does it say "loading", generally the only notice you get is the little red light.
I assume you are using full size cards, not micros with adapters.
Yes full size cards that I have used since the camera was new. I was wrong it does not say loading. It has the spinning wheel on the screen and then says SD card is corrupted.
kvbarkley
Have you tried to do a low level format in the camera?
I have not as I have not figured out how.
From the manual. This is the wrench menu. I always low level format.
Thank you for your help but everything I have said has been wrong (my wife isn’t very good at explaining things). The camera takes and saves photos but when the memory card is put into a computer all the images are corrupted. Have tried multiple different cards and it always happens.
kvbarkley
Are these full size cards? Or micro with adapter?
Did you try the low-level format?
Do they play back fine on the camera? If so, the images on the card aren't corrupted.
Have you tried using the USB cable?
