05-28-2025
07:09 AM
10:14 AM
Hi all - For some time I have used both RAW and jpg settings combined with no issues on my DSLR Canon 80.
Recently, I have discovered the RAW setting keeps shutting off - so only jpg pics result. I change the setting, but after shutting the camera off, the RAW setting does not appear - I have to change again - sometimes it just shuts off even when camera is left on. Any ideas?
This occurs with all my ST cards - I even tried the option of reformatting a card, but still the issue persists - weird one?!
Hopefully, someone out there has experienced a similar problem
Thanks
05-28-2025 07:42 AM - edited 05-28-2025 07:42 AM
Is the camera dial on C1 or C2?
05-28-2025 07:55 AM
Normally have it on scn no issues nor on the AV etc so not changed it since last time I used it
05-28-2025 10:10 AM
What camera do you have?
I recall that some only create JPG images when set to the SCN modes, but obviously RAW is possible when using Av etc.
05-28-2025 11:15 AM
Hi thanks for the input - never had an issue in the past just suddenly started doing it - it will shoot RAW and jpg in sequences- then leave it for 5 mins andRAW shuts off weird
thanks
05-28-2025 12:56 PM
Do ever remove the memory card!
05-28-2025 01:59 PM
Of course I use several
05-28-2025 02:12 PM
When in doubt if some setting has changed that could be causing this, reset the camera back to factory defaults.
05-28-2025 03:01 PM
Yes thanks - that was my next step - cheers
