EOS 80D RAW settings keep deleting after shooting
Desertman
Hi all - For some time I have used both RAW and jpg settings combined with no issues on my DSLR Canon 80.
Recently, I have discovered the RAW setting keeps shutting off - so only jpg pics result. I change the setting, but after shutting the camera off, the RAW setting does not appear - I have to change again - sometimes it just shuts off even when camera is left on. Any ideas?
This occurs with all my ST cards - I even tried the option of reformatting a card, but still the issue persists - weird one?!
Hopefully, someone out there has experienced a similar problem
Thanks
8 REPLIES 8
Peter
Is the camera dial on C1 or C2?
Normally have it on scn no issues nor on the AV etc so not changed it since last time I used it
What camera do you have?
I recall that some only create JPG images when set to the SCN modes, but obviously RAW is possible when using Av etc.
Brian
Hi thanks for the input - never had an issue in the past just suddenly started doing it - it will shoot RAW and jpg in sequences- then leave it for 5 mins andRAW shuts off weird
thanks
Waddizzle
Do ever remove the memory card!
Of course I use several
rs-eos
When in doubt if some setting has changed that could be causing this, reset the camera back to factory defaults.
Ricky
Yes thanks - that was my next step - cheers
Friends and Family
