04-28-2019 07:30 PM
I There,
I dropped my7D camera on the ground and then I got the error 40 Battery issue. Sent it back t Canon for repair but it was more expensive to repair then buying a new one. I then asked them to send it back. I changed this part: Bottom Main FPC CH1-8701 and then got rid of the error 40. When I reassembled it all back the cemera was working fine, it is taking the pictures but is not displaying anything on the LCD panel. I can see that it's not black, it's more greyish... I then ordered another LCD panel and replaced it. When I turned on the camera I got the same issue. I think that maybe a short or a fuse broke somewhere but I don't find anything on the internet to guide me further. Anybody has the knowledge to help me with this issue?
Thanks
04-29-2019 06:30 AM
With only a grey screen showing, it sounds like only the display backlight is getting power but one or more of the data lines isn't intact. Carefully check the ribbon cable from the PC board to the LCD to make sure it is properly in its contact, release it and reinsert it into its connector making sure that it is fully seated and straight.
It is quite possible one or more circuit board traces were cracked when it fell.
Rodger
04-29-2019 09:53 AM
"... it was more expensive to repair then buying a new one..."
There was a reason Canon bid it that way. Cut your loses and buy a new one. You had the correct solution, so do it.
04-29-2019 10:06 AM - edited 04-29-2019 10:07 AM
And I agree with ebiggs advice. Canon priced out what a reliable repair would cost which is designed to:
1. Be high enough to discourage the owner from making a bad decision and
2. Cover the cost of required replacement assemblies to do a truly reliable repair if the customer decides to go through with the repair.
I do electronic repairs on stuff more complex than the 7D but I would likely not bother with a DSLR that was dropped with sufficient damage to cause electronics breakage because if it was a hard enough drop to cause electronic issues it didn't do the fairly fragile shutter and mirror mechanisms any good either.
Repairing stuff involving cables and circuit board traces can be a major and ongoing pain. The only Canon product I have ever regretted purchasing was a "hi 8" camcorder that I probably bought in the late 1980s. It used several horribly low quality flexible printed circuit connecting cables between boards and assemblies and I repaired failures in those many times in the three years before that then fairly expensive piece of gear went into the garbage. It went back twice under warranty for repairs related to those in the first three months and once out of warranty I quickly decided it wasn't worth my time to repair. Current Canon stuff is far better built both in construction and component quality but the Canon SLR cameras of that era were also well built and reliable unlike at least some of their camcorders.
Rodger
04-29-2019 10:11 AM
Hi guys,
Thanks for the reply. For your information I bought a new camera. I would still like to fix the 7d to sell it back or maybe use it as my secondary camera. This is why I'm looking for a DIY way of fixing it.
Thanks.
04-29-2019 02:46 PM
