EOS 70D green and pink display
emiyashi
My EOS 70D has a problem in the LCD display. It shows images (and menus), but everything in green and pink. Pictures and videos are taken normally, it is just the display that has the problem. I already replaced the following parts (shopped at AliExpress) with no results: LCD screen, LCD flex cable with hinge, display board (little board behind the screen). Next one that I can think of is the main board, but that one is quite expensive, so I wonder if anyone has had that problem before and could tell if something else solved the problem, or if anyone can suggest anything else to look at. Thanks.CanonEOS70D_display.jpeg
2 REPLIES 2
ebiggs1
If you did the listed repairs and you did them correctly, it leaves  little doubt the MB is bad. Doesn't it?
Thanks, that is what I thought. But it is a very expensive part, so I would really like to see if there is someone else who had a similar problem and how it got fixed.
Avatar
