EOS 70D Settings for Northern Lights
Lorenayr
I JUST GOT A SECONDHAND EOS70D IS THERE SOMEONE WHO CAN HELP ME WITH THE SETTINGS? THERE IS SO MUCH IN YOUTUBE IM CPNFUSE
3 REPLIES 3
deebatman316
I would reset both the main and custom functions back to factory. Then set the mode dial to P Mode with Auto ISO. Also learn the controls of your camera. Don't try to learn everything at once.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
normadel
To begin with, you should have the Canon manual for the 70D. Look for one on eBay, or at UsedPhotoPro.com. It is worth spending a few bucks to get the printed version.  Here is the online PDF you can download.......https://www.usa.canon.com/support/p/eos-70d
Also, look for a book  on the 70D, in bookstores, Amazon, library, etc. They are often easier to learn from than the factory manual.
jrhoffman75
  1. Use an aperture of f/2.8 or the widest in your lens
  2. Adjust an ISO from 3200 to 8000
  3. Set a shutter speed between 1-12 seconds
  4. Adjust your white balance to 3500k
  5. Set lens to MF and focus manually on a distant light or object. Tape lens w/gaffer tape so focus doe...
  6. Select a shutter delay of 2 seconds
Some aurora are static and just light up the sky. Others are like curtains of light and are moving; the moving kind need a shorter shutter speed to stop the motion.
Decide on a shutter speed and then adjust ISO to get the image you want.
