03-29-2024
07:12 AM
08:37 AM
I'm receiving error 70 when trying to turn on live view or take picture on 6D mark II.
LCD display is working fine. I can access menu.
Few testing scenarios on video
https://www.youtube.com/watch?v=ZBTBY2AHzsU
Any ideas what is causing problems? I tried different lenses/ batteries and removing/ formatting SD-card. I tried remove battery/ SD-car for few hours. I was able to see older pictures on LCD panel.
04-01-2024 06:03 AM - edited 04-01-2024 06:09 AM
Just for info for people with a similar problem. I fixed the camera by disconnecting and reconnecting the flex cable between the motherboard and the sensor. I think I accidentally partially disconnected it earlier. 20240328_235051.jpg
03-29-2024 07:49 AM
Not a good sign. Stop cleaning it.
What lens are you using? I suspect your camera needs service.
https://support.usa.canon.com/kb/index?page=content&id=ART177684
03-29-2024 08:29 AM
Samyang 12mm f/2.8, Sigma 24mm f/1.4 art. The same error for both
03-29-2024 09:22 AM
Do you have a Canon lens to try?
03-29-2024 12:37 PM
no
03-29-2024 01:00 PM - edited 03-29-2024 01:05 PM
I didnt mention that this camera was astro-modified. Original UV/ IR filter was replaced(not by me) with Baader filter that allow more IR light[1]
After modification the camera was working fine but I was not able to focus with my 12mm lens- focus was little bit behind hard stop. After some investigation I found out that it was most probably caused by incorrect sensor position- maybe less than 1mm.
After few weeks I found courage to try to fix it by myself. There are 3 screws on springs which keep sensor in correct position. I tried to adjust them by 1/4 of a turn in clockwise direction but I was not able to move then in any direction... So I reassembled camera but I am now receiving error 70. The most probably I accidentally damaged sensor?/ motherboard?/ ... with my lumberjack fingers and the only solution is fix/replacement at canon service but first I wanted to try all other possible fixes.
Thanks anyway!
[1] https://noctilove.co.uk/astro-modification-guide/
03-29-2024 04:56 PM
I’m sorry. Your camera has been modified and you have taken it apart to make repairs. Your issue is beyond my ability to diagnose in a forum.
