EOS 650D LCD Screen
Geoff-01
when turning on the LCD screen appears for 1/2 second than goes blank, menu, info, play, etc. all come on screen when touched but not starting the way it used to, its a old camera which I haven't used in a couple of years, I think I've forgotten to press or not the right button would appreciate help thanks
3 REPLIES 3
Tronhard
Hi Geoff:
My first thought is that you have pressed the INFO button at some state and set it to a blank display.  So I suggest  that after you turn it on you press that button several times to see if something comes up.
If that does not work, then looking through the viewfinder, use the menu system to find the function to do a factory reset - it's under the wrench menu.
cheers, TREVOR
Before you ask us, have you looked in the manual or on the Canon Support Site?
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
Geoff-01
thanks for the help appreciated
Did the solution work?  If so please mark the solution post as resolved so others won't keep trying to fix it and others with a similar issue will know what to do.
cheers, TREVOR
08/18/2023: Canon EOS R5 C training series is released.
CR-N700 - Version 1.2.0
CR-N500 - Version 1.3.0
CR-N300 - Version 1.3.0
CR-X300 - Version 1.1.0
06/30/2023: New firmware version 1.0.5.1 is available for EOS-R5 C
EOS R6 - Version 1.8.2
EOS R7 - Version 1.3.1
EOS Rebel T7 - Version 1.2.0
EOS R5 - Version 1.8.1
