12-29-2017
09:36 AM
08:55 AM
hi ..
i have a dslr canon 60D
I have a problem with my camera
In all the settings I have a black screen and there are only the ISO settings and the battery and the like and I can not see what the camera imagines
What is the solution please
12-29-2017 11:07 AM
@oussamabenabila wrote:hi ..
You either forget to remove the lens cap, or the image sensor is dead.
12-29-2017 04:48 PM
my image sensor is dead. ooooh what the solution
08-13-2022 03:07 PM
Before you do anything else, use the menu system to reset the camera to factory default. If necessary look through the viewfinder to do so if you can't see the LCD display.
After doing that, make sure the lens cap is off, set the camera on P mode, looking through the optical viewfinder, take a photo. Use the review button to check the imager and then use the INFO button to cycle through the display and see what you get. If nothing is displayed in review then the sensor is dead or the LCD display is malfunctioning. If it is the latter you could still use the camera by just using the viewfinder but if it is the sensor, then the camera will cost more than it is worth to repair.
