EOS 600D - LCD is up-side-down - how to rotate the screen?
Stranger78
Hello,
I have a problem with my EOS 600D. Not sure what happend, but the display is up-side down when it is "docked" to the camera. When it is "released" and turned it is correct. Is this an error or some setting? I can not find anything related to this in the menu. I have reset the settings but still I have the same problem.
Up-side down..
Normal view when the display is not docked..
Thank you for any help. I also have tried to google this without no luck..
2 REPLIES 2
Tim
Hello Stranger78,
We are sorry to hear that the LCD panel on your EOS Rebel T3i (600D) appears to be upside down when docked into the camera.  There is an auto sensor that should detect when the LCD panel is back in position and rotate it accordingly.  Since this is not the case, you may wish to send the camera in for evaluation.
You can start the repair process on our web site here.
Hello Tim,
Thank you for your reply. I'll contact Canon here in Europe to get the camera evaluated.
