07-06-2021 01:27 PM - edited 07-06-2021 01:28 PM
This issue is beginning to become bothersome and I was wondering if anyone has a solution before I send my camera off for repair.
On the camera screen, I see strange green and magenta lines and fragments when I actively use the camera. When I pull the files off my SD card, the JPEG images capture the green and magenta lines and fragments. However, when I open the RAW files on photoshop and lightroom the lines and digital fragments disappear.
Unfortunately, when I do any recordings the video has all of the green and magenta digital fragments and there is nothing I can do to remove them from the video.
I tried to update my camera's driver but that did not resolve the issue. At this point I am assuming my camera is defective even though I bought it brand new from Best Buy back in September...
This is an example of a jpeg file from the sd card after shooting with the EOS R.
07-06-2021 03:06 PM - edited 07-06-2021 03:08 PM
Welcome to the forum.
Looks like it might be chromatic aberration.
What is chromatic aberration? - beginner's guide | Adobe
Which lens on your R6?
07-06-2021 03:33 PM
Are you speaking to the magenta lines around say the edges of the belt buckle? If so, see John Hoffman's reply about chromatic aberation.
However, I see three horizontal single-pixel cyan lines through the image along with quite a bit of magenta/cyan noise all throughout (especially the background). I'm not sure what the cause of that would be.
07-06-2021 03:41 PM
07-06-2021 03:42 PM
Thank you!
I am currently using the Canon - RF 35mm F1.8 Macro.
07-06-2021 03:46 PM
Here is a link to a Google Folder with a jpeg and raw files of the same image.
https://drive.google.com/drive/folders/1XWSIBA55hklVEMW1Jf6VZVQEJaAugUyV?usp=sharing
07-06-2021 08:06 PM
I was able to open your RAW image in Photoshop and it didn't contain any artifacts. Saved to a JPEG in sRGB color space and again, no artifacts at all. For some reason, the JPEG images being created in camera are containing strange artifacts.
Something's definitey going on then with your JPEG files and videos. I would call Canon and see if this may require a repair.
07-06-2021 09:26 PM
Sounds good. Thank you for helping out!
07-07-2021 12:46 AM
The raw file. Shouldn't look like that.
07-07-2021 06:22 AM
I downloaded the files and processed them in Canon DPP.
I do not get the stepping that Peter shows.
One strange/interesting thing I did observe: I had DPP download the DLO lens data. When I turned on DLO the image would sometimes display the green lines and the red/greeen speckles if I scrolled the full size image in the display. It wasn't always showing, and it was transient (so I couldn't get a screen capture) but it was there.
