03-14-2023
06:10 PM
06:19 PM
Tiffany
I have a 5D with a brand new, fully charged battery and a brand new memory card. Turn on the camera, go to format and the camera states that it is busy formatting. It’s been that way for 20 minutes. I turned off the camera, removed the battery and memory card, return them, turn the camera back on and start the formatting again and it still says busy. What am I missing. Thank you for any help with this issue.
03-14-2023 06:47 PM
Have you tried using a different CF to see if your current one is faulty.
03-14-2023 07:18 PM
No I have not but will give it a try. Thanks 👍
03-14-2023 07:22 PM
Also inspect the pins inside the camera with a flashlight to make sure there NOT bent either.
03-14-2023 07:26 PM
5D needs firmware 1.1.1 to be able to use larger CF cards
