EOS 550D What is this piece?
Atheer
I removed the lens to clean the sensor and this piece fell of. I do not know if it fell from the lens or sensor
14 REPLIES 14
Tronhard
VIP
VIP
Hi and welcome to the forum.
I cannot see an image. Can you please check you sent one?
cheers, TREVOR
Without an image, there is no way for us to help identify the part.
The photo button above will allow you to attach an image
deebatman316
Hello Atheer Welcome to the forums. The part that you show in the picture is most definetly from the camera body and not the lens.
-Demetrius
40D, 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
Thank you. I uploaded it
Please check the picture
Please check the picture.
kvbarkley
I don't see anything remotely like that inside my mirror box. It looks like the contacts for the SD card, but there is not enough of them.
Agreed. I am sure it's not from the lens. Either way your camera needs to the attention of a sercice tech. Canon is unlikely to touch it - it's way out of service life.
Does the camera still function correctly? If so your cheapest option is to use it until it does not, then consider a replacement.
cheers, TREVOR
MikeSowsun
That looks like a part from your lens. Your lens will not work properly without that part and it is probably cheaper to buy a used lens rather than repair. Lenses often have flexible ribbon cables but they also have contact strips to keep electrical contact on the barrel as you focus or zoom in and out.  Which lens or lenses do you have?
Mike Sowsun
How can it possibly get past the rear element and mount? I know "weather sealing" is more of a marketing term, but it is not *that* bad. 8^)
