EOS 50D continually fires without me touching the shutter.
EscO7
camera fires without touching shutter release. Put battery in after charging, turned camera on and after a few seconds camera started shooting. I have to turn camera off for it to stop, turn camera on and it starts firing again.
9 REPLIES 9
jrhoffman75
Check if maybe something is jamming your shutter button down, like a piece of sand.
Thanks I will try that. Is there a safe way to clean shutter button if something is jammed in there? Canned air or something?
Use a corner of a business card or a piece of paper. Insert between button and camera housing and move around circumference of shutter button.
Before you you do that just try depressing button a few times.
Tried that, still the same. Button seems ok, feels normal. Would moisture cause something like this?
It could. Did the camera get wet?
Yes, I got caught in the rain, it got wet but not that much. I was fairly close to my car and it wasn't exposed but for a few minutes.
That may be all it took. Remove battery, If you have a dehumidifier or air conditioner let the dried air blow on the camera; cover it with a cloth to shelter from dust, and hope it dries out. Wait a day or so and see what happens. Maybe you can recover it.
Thanks for you're help. I'll do that   I hope it works. Thanks again.
Hope it works. Good luck.
