EOS 40D Card Formatting Error
Sinnlos
I was so disappointed when i got an EOS 40 D body to play with from a Camera Club member as it will not work -- all I get every time is message 'CF card not Formatted, Format Card with this camera' so I find FORMAT in MENU and click OK and another message says ' Cannot Format, change the CF Card' -- so even with a DIFFERENT CF Card I get the Same Messages even though the different card HAD been Formatted. . In the top LCD screen it says 'ERR CF' -- and there are NO bent pins !
2 REPLIES 2
p4pictures
What capacity CF card are you trying to use? The camera has some limitations and is not able to use larger capacity cards.
Brian
deebatman316
The EOS 40D works best with 4 or 8GB CF Cards. Anything 16GB or larger doesn’t play nicely and causes issues. Also DO NOT USE a CF-SD card adapter stick with CF Cards.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
