12-26-2021
02:10 PM
02:43 PM
I use my Camera about Twice a Month. Having, not used it for a month I returned to it, and started taking pictures outdoors only to discover that none of them were saving them too the memory card. My initial thought was that the fault is with Memory Card. But the card was working fine last month, when I was taking pictures, and also, I did try to switch the lock on the Memory Card as advised, but this created a error message saying something along the lines of "The Lock on the Memory Card is on." And then when I pressed the button to take a picture when the lock on the memory card was on, it wouldn't even take a Picture... I know this is a long story, but what I'm saying is, I don't think the reason the Pictures are not saving to the memory card is because of the lock on the memory card, or the position of the memory card. I think it's something else.. Can someone help. Also its not the quick take in the setting, i tried that too didn't make any difference! But the camera is still not taking pictures!?? Can someone please help??
12-28-2021 08:59 AM
Yeah! I think that going to the camera shop is going to be the best idea. 🙂
12-28-2021 09:00 AM
OK, I will have a go at Formatting the Card... (Card Completely Blank After Last Time I took the Camera Out?)
12-28-2021 09:01 AM
The Pictures from my Last Session were still on the Card 🙂 Yeah I will take it to the camera store and see what they say..?
12-28-2021 09:04 AM
Actually that's not true, the photo's from the Previous session were on the card, just not from the time I took the camera out over Christmass.. SO that's why I was hesitant to format the card... But by the way... How do you format the card?? Do you do it on your computer, by the RIght Clicking and choosing format in the drop down... or do you, use an option on your camera??
12-28-2021 09:06 AM - edited 12-28-2021 09:08 AM
Safely download all the images from your card to the computer.
Then use the Format Card option from the camera menu to format in camera.
Also, have you disabled the "Take images without card" setting in the menu.
12-28-2021 10:17 AM
OK , I'll try that... can't say I've seen that option to "Take Images Without Card...?"
12-28-2021 10:22 AM
Something like this
