EOS 4000D No sound while video playback
jabfeliciano
I have a Canon EOS 4000D. While I was playing my recorded video, there is no sound? Is there a setting on the camera to increase the volume playback? Thanks!!!
I have downloaded and referenced the Canon 4000D manual, according to which, if the camera is being used to playback movies, it has to be connected to a computer or a TV screen via the HDMI socket to do so.   I enclose this page from the Canon 4000D manual.
And...  Regarding controlling volume with the camera
cheers, TREVOR
14 REPLIES 14
kvbarkley
This seems to happen to some foks. Does the sound play when you view it on the PC or phone?
Tronhard
VIP
VIP
Your post did not really specify where you were attempting to play the video back from, but from your comment about a sound volume om-camera device I assume you are attempting to view the video from the camera.  If you read the manual:
On P214 it states "The camera does not have an audio/video OUT terminal. Therefore, the camera cannot be connected to a TV set with an analog AV cable."
AND
On P216 it states "Check the sound recording on a TV or computer.  The camera is not equipped with a speaker"
So you have a couple of choices:
1. remove the card and put it into a computer or compatible TV
2. connect the camera to a computer or TV via the HDMI port and a cable - sold separately.
I hope this clarifies the situation for you.
cheers, TREVOR
MikeSowsun
Check your manual. There is no playback speaker on your camera.
Mike Sowsun
cheers, TREVOR
  1. “The camera is not equipped with a speaker”.
Good catch.... I guess the 4000D is the first Canon DSLR not to have a speaker. Even entry level cameras like the T6/1300D and T7/2000D  have speakers.
Mike Sowsun
Good catch.... I guess the 4000D is the first Canon DSLR not to have a speaker. Even entry level cameras like the T6/1300D and T72000D  have speakers.
Hmm.  I wonder how it manages to “beep” when it gets a focus lock.  =8^D
jodiweitz
I have a Vixia HF R82.  The playback sound was working well, until I plugged a headphone in the AV OUT port and took it out again.  Now, the auto level indicator always displays and there is no sound on playback.  Any ideas?
Check your AV output setting and make sure AV/Headphones setting is put to AV also verify your levels setting either in Automatic or Manual, if in Manual then you have to adjust the levels yourself.
Start a new thread down in the camcorder section.
